arcteryx
Supporting Vendor
Need some assistance on this one as I am exhausting my ideas/options. My 94 runs like crap and appears to be missing and I think it's something odd based on what I have done below.
Symptoms
- when driving there is noticeable stumbling and hesitation. I do not want to drive it. Idle it is not noticeable when in P, but is when in gear
- oil pressure gauge is high on start up, normally it's low. Could be a bad gauge as they are prone to error
Things Done
- At first the thought was the spark plug tube seal in the valve cover was so old brittle that oil was coming into the tube and fouling up the plug. This was true for #3. I replaced the tube seals with new ones
- Tune up - new plugs, wires, cap, rotor, valve cover gasket
- removed plenum and replaced all hoses with new OEM hosing. Tested all VSVs which were all working
- fuel pressure was tested and passed by my indy. I did replace the fuel filter about 15K ago, thinking about doing this again, although if there was something in the fuel lines, it should be intermittent as the blockage should move. This is constant.
- timing (re)adjusted
- tested and swapped out igniter. The secondary pulse resistance was high
- ECU and MAF swapped out with known good ones
- tested dizzy resistance
- dipstick shows beautiful oil, no white/cream color indicating a blown HG
I know the dizzy has a leak at the o-ring and dripping down the side of the head/block, but it's dry inside and should not affect the above. The issue is persisting after doing the above, so any help is welcomed.
Symptoms
Things Done
