Debugging idle issues/misfires, I've determine I've got zero compression on the #2 cylinder. Popping the valve cover, it's pretty clear that there is a stuck valve in the open position on the #2 cylinder (I believe the intake valve).
Any suggestions, hints, or gotchas with fixing this? What should I expect pulling this apart (this will be my first attempt at a valve job).
