My northern-sourced HDJ80 saw a bit of salt. I had to grind/cut most of the bolts off the underside (cross member etc) to get the engine out.
I'm currently trying to separate the T-Case from the Transmission and I really would prefer not to break any bolts OR the alloy cases. No penetrating oil is going to get into the threads and, as much as I love a good torch, I am unsure how these alloy cases take the heat.
Thoughts? Torch will be fine? Use the Ugga-Dugga or another method?
