Thanks in advance…
Awesome. I have 205K on the truck. It is a 2000 LX470.
I'm not sure if there are differences within the series, but at least some LC100s have replaceable ball joints. how-to video
I'll be attempting all 4 of mine this weekend.
I agree, and it kind of looks like some kind of grease/oil has been splattering around.Lowers are “technically” not replaceable otherwise Toyota would offer replacement ball joints. That said- they can be pressed out - many have done it; choose 555 Sankei Brand- ask Cruiser Outfitters. If uppers aren’t loose and boots are good- wait.
As for the vibes and bump you heard- I agree with krispy- that presents like CV axle. Check boots for slinging grease, cuts or tears- and any “remarkable play up/down/in/out. Pull grease cap from flange to be sure your snap ring is connected.
If the hum happened after a strike from underneath the first thing would be to check propeller (front and rear drive) shafts. Look for dents or impacts to shaft tubes, but far more likely the damage will be on the rear shaft as the front is more protected and thicker walled. A minor imbalance will cause a harmonic vibration throughout the drivetrain.
Could a wheel weight coming off cause this? Large knock = weight flying off, vibration = unbalanced wheel
