I got in my 40 this morning and noticed a real strong smell of gasoline, even before I started the engine. After starting it and looking the truck over I noticed a wet spot around the drain plug under the gas tank on the underside of the truck. (I'm assuming it's a drain plug) There was also a wet spot on the frame. I was in a hurry to get to work as I had a meeting I absolutely had to be at. I drove to work with the vent windows in the back open and both windows and vents in front also open. I'm guessing I have a leak in the tank, but I have a question. I think right before I last drove it, I filled the truck up with gas. I always really top off the tank to the very top so as to have a cushion against running out.
Is it possible that I'm somehow smelling overflow? My truck has had the charcoal canister removed.
