The bolt is out. The threads or if there was a nut in hole its not there thanks for respondingAre the threads in the hole actually stripped out, or did the bolt break off?
I thank you for your help i was thinking of drilling a hole right thru and using nut. The seat would hide the nut. But your ideas are good too thanksYou probably have to take it apart and see how much meat is left in there before you can tell what needs to be done. There's helicoils, nutserts, tapping it to the next size thread, or drilling it out and welding a nut in there flush, many ways depending on the situation. Probably more I'm not thinking of but its inside a tube so you can't access the back to use a nut. I just repaired a seat bottom hinge hole by welding it up, drilling and tapping it.
