Hi folks, I need help sourcing a vibration my truck has developed (99 LX470). In the last few thousand miles, I have developed a fairly significant vibration between 65-72 mph, between 2,100-2,300 RPM, and only in 4th gear (my top gear). A few things worth noting:
- I start feeling it in the steering wheel, but the entire car shakes.
- If I drop the transmission to neutral during the shaking it gets some better, but doesn't go away completely.
- I recently replaced the steering rack/LBJ's/UCA's/sway bar end links, and all is good and tight.
- The tires have been on the truck for over a year without prior issues.
- Rear upper and lower control arms have been replaced within the last few years.
My thought is that is is likely the u-joints, but I haven't singled them out. I went under the truck and grabbed both yokes and pulled/pushed in every possible direction, but got no movement (granted the truck was in gear). The driveshafts are original and I'm now at 293k miles. I need to get the transfer case in neutral and recheck.
Anyone else have thoughts on what this might be? I've done nothing else to the truck recently that would cause a vibration (lift, etc.).
Thanks in advance!
Thanks in advance!
