So my 85 BJ 60 has been reading some strange temps for a while now. I pressure tested the system a month ago and found that the water pump was leaking so i installed a new one from Toyota; while i was at it i installed a new thermostat (part # 90916-03103) and rad cap (13lb). I flushed the system, installed new coolant etc... After doing all that i am getting weird temp readings; temp rises to almost red then drops. There also seems to be a correlation with the heater; when i have the heater set to high the temp goes up and if its at cold it stays relatively constant. I am also loosing coolant from somewhere. I have check the hoses and there does not seem to be any coolant in the oil (want to rule out the head) and havent noticed any coolant under the truck. I have only seen some coolant at the bottom of the rad (on the tray). So im trying to figure out if its:
a) the heater core
b) the thermostat (should i switch to a 82 degree) or
c) the rad (coolant leaking out and evaporating)
Anyone have any suggestions?
a) the heater core
