'Strange' Noise...Please Advise
Discussion in '80-Series Tech' started by TX80Fan, Mar 4, 2007.
  1. TX80Fan
    TX80Fan
    342
    3
    Feb 27, 2007
    State of Flux...
    I'm a 'bonified' newbie as far as LC's go...so "hello" to all and I'm thankful for such an informative site about our vehicles. I'm getting a strange 'whirring' noise coming from the rear of the vehicle in overdrive at approx. 55mph under load / acceleration...any ideas? TC, Trans., Rear Diff.? Other than this noise...the vehicle drives out great! Any / all help is very appreciated...Thanks
  2. Romer
    Romer fatherofdaughterofromer Moderator
    10,690
    1,719
    Sep 14, 2003
    Centennial, Colorado
    If its more of a whistle, it's likely somewhere in the exhaust. If it's no a whistle, could be drive train; dry ujoints, failing U joints, unbalanced drive shaft.
  3. TX80Fan
    TX80Fan
    342
    3
    Feb 27, 2007
    State of Flux...
    Cool. Thanks alot...I really don't think it is an exhaust issue. I'm going to start with the U-Joints...they probably need lubrication or replacement.
  4. Romer
    10,690
    1,719
    Sep 14, 2003
    If you think its U joints, easy way to trouble shoot is to pull the drive shaft and engage your CDL. Drive like normal. If you don't have a CDL switch, there are various methods to engage it.
  5. knorrena
    knorrena
    1,286
    9
    Nov 5, 2005
    Calgary
    My experience has been that if a ujoint runs dry enough for you to hear it, then the best bet is to replace it. All the grease will do is bandaid the problem till you forget about it, only to be reminded at a less convenient time.
    Karl
