Strange, intermittent noise. Any thoughts?
Meridian, ID
Ok, after a search and about two hours of reading, I'm still not getting anything that seems to fit.
Intermittent noise/vibration. Vehicle is 100% stock AFAIK. The wife has described it as emanating from the right-front wheel or thereabouts. It sounds like something is rubbing against the side tread of the tire, and the vibration can be felt through the floorboard. The sound is lowish in frequency, almost like driving over a metal grate such as the surface on some draw-bridges or the "wake up" bumps on the side of the freeway, but not quite as loud. Initially, it doesn't strike me as metallic in nature, but anything's possible. It is brief in duration, and doesn't seem to be induced by anything in particular. Happens to her while driving on straight, flat, smooth pavement, goes for a few (1-5) seconds and then stops. Also has started after making a turn, or going over a dip/bump in the road. Personally, I have only heard the sound once, at 35mph after about 20mi of test driving at varying speeds. It doesn't seem to be speed sensitive, but who knows. I have not yet had an opportunity to take the wheel off, but a thorough visual inspection has not revealed anything out of the ordinary. No splash guards, etc. hanging down to interfere with the tire or anything. The truck has 117K on it, and I plan on doing the axle service at the 120k interval. I did, however find a couple of oil spots on the garage floor a couple of weeks ago that appeared to have dropped from the right front knuckle area. Knuckles are caked in the typical grease/dirt gunk.
The sound reminds me of the ABS test cycle that occurs on my Jeep XJ as I begin to drive. Kind of a "Vrrrrp". Could it be electronic?
I've tried to be thorough, but let me know if you need more info. I hate these types of things due to their being difficult to diagnose in person, much less over the internet. It's probably something minor, so I'll continue to drive and wait to see if it gets worse, but I thought I'd throw this out and see if any of you have experienced anything similar.
Thanks in advance.
What you describe sounds to me like the dry spindle issues several of us have experienced. Does it just come on abruptly for a few seconds them disappear as quickly? If it is that, its causing damage driven dry and you need to tear into the sterring knuckles now, not in 3k miles. And I would do it when you can afford a few days down time, should you find that you have order new spindles. Search for spindle here in the 80 forum and you should find some info and pics.
Uggh! Not what I wanted to hear. :frown:
Yes.
I think I'll search "dry spindle" and see if I can get further clarification.
Thanks for the quick response.
Uggh! Not what I wanted to hear. :frown:I think I'll search "dry spindle" and see if I can get further clarification.Thanks for the quick response.
I just hit a few "spindle" threads and they are easy to find. This hits close to home for me because the one and ONLY time I have ever paid a Toyota dealer to work on one of my Land Cruisers was on my first FJ-80 that made that sound about 3 days after I bought it. Scared the hell out of me. After I got the $858 repair bill (they rebuilt both steering knuckles at the same time) I said "Never again."
Wow guys, thanks! While I'm not happy about it, I sure am thankful for the responsiveness of this board.
Landtank, you are right. The problem emerged right around the time the temperature started to dip below freezing.
elmariachi, thanks for pointing me in the right direction. "Dry spindle" yielded lots of pertinent info.
So, now I guess I should probably park it until I can do the axle service. Once I get it all opened up what am I looking for? Anyone have pics or a link to another thread that does? I had planned on ordering the rebuild kits from Cruiserdan, but should I be ordering new bushings as well, or am I just greasing them when I get in there? New spindles? What else should I be looking at replacing or servicing while I'm in there? Bearings?
I think of myself as a :banana: guy, but through the encouragement of this board, I bought a good set of wrenches and have been thinking about attempting the axle service in the spring. I guess I wasn't expecting to have to do it this soon. I read through the axle service tutorial in the FAQ a few months ago and recall it being fairly straightforward.
Am I to assume that since it is making noise, that the spindle is already damaged? I expect that since the truck is new to me, and it has 117k on it, that the axles were most likely not serviced at the 60k interval. I assume that the spindle bushings should not be dry and making noise had it been done by the P.O. at the recommended interval.
Crap, I probably need to buy a torque wrench and an FSM as well huh? Well, even if I have to buy some tools, I suppose it is still cheaper than having someone else do it.
Sorry for all the questions, I'm just a little nervous about attempting this myself given my lack of experience. I'll keep using the search function to try and find answers.
Thanks again elmariachi, CJF, and Landtank!
IH8MUD is the best!:cheers:
Get a full rebuild kit from Dan. You really won't know about the bushings until you tear into it. https://forum.ih8mud.com/80-series-tech/70626-noise-sounds-like-driving-washboard-high-speeds.html
elmariachi-
Great link! Thanks for providing.
Ok, well I need to do the axles anyway, so I guess now is the time. I'll order the kits from CDan and get 'er going. I'm not sure exactly how to ID whether or not the bushings/spindles are bad. I guess, like you said, I'll know when I get in there.
Do I need any special tools to do this, like a torque wrench?
Again, thanks so much!
