Strange electrical issue...
CreeperSleeper
Cascade Cruisers
Canby, OR
Every once in a while I will flash my brights (or something like that) and my radio and heater fan will "reboot". (Shut off for just a second and then turn back on.) This happens maybe once every couple of weeks. Then the last 2 days the automatic turn off on my headlights hasn't worked.:confused:
I have no idea if these are related and electrical issues are not my strong point, so feel free to ask questions that I haven't thought of. However, this is making me kinda nervous. TIA
Sounds like a "ground" issue...and like most electrical problems they can be hard to track down. I'd start with the main grounds on the truck and make sure they are solid.
That's kinda what I thought too, but I'm a little green in this area. Would the ground on my sub amp have something to do with it? The power is coming straight from the batt and it is grounded on the body, but I've started to notice a slight "dentist drill" when it is on but the sound is muted... That will be fixed tonight.
Eric's_bruiser had the exact same problem. We changed both the + and - battery cables to get rid of it completely. We started with the ground since it was easily sourced locally which helped but didn't get the whole job done. Eric then ordered both from a dealer and once installed evrything was fine.
Chad,
I doubt the amp wire is the culprit. 10 ga. is pretty small for that long of a run to a high power amp, but even still, probably not it. That might contribute to the dentist drill issue, which you could isolate by putting a filter in the wire (available at car stereo places? Crutchfield? I haven't seen one in a while) I have seen bad grounds to amps causing goofy things with the amp, but unless you are running the main door speakers off the amp, you would probably only notice the sub cutting out when the ground was not good enough.
Is the head unit losing power completely, or just the sound cutting out? If it is losing power completely, you might check the wiring diagram to see where the factory radio power and the heater have common power wires. Most likely would be after the two systems are running off the same power. You might also plug something into the cigarette lighter to see if that loses power as well. The more you can isolate to that circuit, the more you limit the possible places the ground fault could be.
Good luck.
Steve
Thanks for the input guys. Just to clarify, the 10 ga wire is a factory wire coming off the batt, not for the amp. The amp power wire is 0 ga. I regrounded the amp last night and the dentist drill is gone, but I'm starting to think my problem is the Rockford Fosgate power terminal on the batt. It looks a little getto the way the PO set it up... I'll replace that and the ground strap and see how that works. It's only money, right.
If your batt. terminal is at all sketchy the voltage to your whole truck will drop. Add up all the cumulative resistance of all connections for your stereo and it may very well cause it to shut off if the voltage drops too low. The brand of terminal should not be an issue. But the quality and cleanliness of the connections could be. How is your system set up? How many amps are you running. When this reset happens does the clock reset? Are you using the factory ground spot for the stereo?
My HU is wired into the factory harness along with the CB, but I am running my own power wire from the batt to the HU. I only have 1 aftermarket amp (still using factory amp on factory speakers) and it is grounded to the body and powered from the batt. As for the clock, the display turns off and on, but it usually doesn't effect the time.
