Stop the noises in my head!!!!!!!!
Discussion in '40- & 55-Series Tech' started by MoGas, Feb 29, 2004.
  1. MoGas
    MoGas Central Scrutinizer SILVER Star
    2,037
    Media:
    7
    Albums:
    3
    49
    Jan 26, 2004
    Air Mobile
    1989 FJ62
    Every time I am at a stop while the trans is in drive I get a vibrating/rattling noise that I have found to be one of the rods for the headliner vibrating against the roof.
    How can I get rid of this noise without too much trouble????
    Thank You,
    Dave
  2. MoGas
    2,037
    Media:
    7
    Albums:
    3
    49
    Jan 26, 2004
    Air Mobile
    No ideas????
  3. pygpen
    pygpen
    472
    1
    Dec 9, 2002
    Benicia, California
    Remove the headliner and chop the top!
    Summer is coming. :D
    Sorry not any help....
    PMK
  4. jasond73fj40
    jasond73fj40
    50
    Feb 25, 2004
    To funny! I have the same problem.
    I was looking at the work involved with pulling down the headliner & decided its easier to ignore it & keep the RPM up to stop the rattle at idle.
    Do you still have a functioning radio? Count yourself lucky & turn up the volume. My power has somewhere along the line cut out so my radio & cigarette lighter don't work.
  5. Rice
    Rice
    4,626
    Media:
    10
    Albums:
    1
    5,743
    May 2, 2003
    GSO NC
    I've not tried this so consider it a hunch ...
    How about putting some silicone sealer in a syringe (the cheap kind with just a plastic tip ... no needle) and punch it though the head liner (so there will be a small hole) and inject between the rib support and roof. With a big enough tip perhaps even a needle could work and you'd have a smaller hole in the liner.
  6. 60wag
    60wag SILVER Star
    1,928
    43
    Jun 25, 2003
    Boulder, CO
    If the noise is close to a door, you might be able to get to it. Pull the door trim off. You can peel the headliner away from the doorframe a bit and get a small opening between the liner and the doorframe. I did this to slide some cardboard and a hotpatch up behind my liner. The cardboard was a surface to press the iron against to stick the hotpatch in place. Not a perfect fix - but better than an open rip. You might be able to get some caulking on the rattling rib, then close up the opening when the door trim goes back in place.
  7. brian
    brian SILVER Star
    8,808
    2,214
    Feb 7, 2003
    lebanon,pa
    [quote author=Rice link=board=1;threadid=12313;start=msg113830#msg113830 date=1078251235]
    [/quote]
    even a small slice, say 1/4" or so would allow the tip of a caulking gun loaded with said sealer to get the job done.
