Stock radiator question ???
Albuquerque, NM
Website
www.nmia.com
Does anyone know if the plastic hose bibs on the radiator have a metal reinforcing sleeve in them? I forgot to look when I had mine apart last week. The lower hose has been weeping a little all week after I put it back together so I put a screw-type hose clamp on it but don't want to tighten it too much unless it has an internal reinforcing sleeve.
Donco, not sure about the metal reinforcement so I wouldn’t over tighten it. Instead, cut the small amount off the end of the hose you are trying to reattach and see if this helps.
Dean
stock radiator
calamaridog said:
They have nylon thread in the middle but no sleeve.
Thanks, I gave the lower hose a couple twists back & forth & slid the factory clamp back enough to make room for a screw on clamp and set it snug but not tight & hasn't leaked even a drop for 3 days.
