@scottryana and @landtank
So AC running today mid 80's driving 70MPH under 10-15 pounds of vac I see the A/F meter going all over the place. Rich lean rich lean.
The computer tries to compensate but it is not fast enough.
@landtank Timing is massive. Before I replaced 1 knock sensor and adjusted the timing I pinged like crazy.
I would have to check the timing again, comes to life hard at 2800- 3000 but you know she is there at 2k.
You might want to change your fuel pump relay. I've seen these things not control the pump consistently on stock trucks.
On my SC I've been using NGK BKR7E plugs which are 2 heat ranges cooler and a copper plug. They have been running flawless even in the dead of winter. You can get them at advance auto for under 2.00ea, I'd give them a try.
