Hey collective — have had Bleu for almost a year and have been loving the daily drive.
My plan was to drive her for a year and fix things as they came up to make sure the basics were good.
Once she warms up she has always ran a bit differently, it’s tough to articulate but let me try.
Starting — when temps are below 40 takes 2-3 gas pedal pumps with choke out to start, I’ll let her warm up for 3-4 minutes then she purrs along great at 700 rpms when I push in the choke. My drive to work is roughly 10 minutes going 25 mph is, I don’t notice any issues there.
On lunch I run home to let the dog out but it’s the trip back to work where I notice is, the idle will slow way down and she will chug, I have to pump the gas or pull the choke out to keep her happy otherwise RPMs drop to 300 and sometimes she dies. Then she does not want to start.
Plenty of gas in the fuel filter and it’s not visably fouled, carb window is 1/2 full of fuel, I checked that relay that sometimes can burn out (as in when I turn the key to on there is that clicking noise), her running does not change when I uncap the gas tank.
I think it’s a fuel problem as giving her gas solves the issue.
Thought number 1- fuel pump is going? But why would she run fine on relatively short drives? Hmm
Thought number 2 - vacuum leak? I purchased a can of starter fluid and will check that later today.
Last thought — this morning I noted that at the base of the carb there was a bit of fuel, the rubber gasket thing appears to be worn out and broken. See picture, so what is that and could this be the source of my issues?
Lastly what else should I check? I may get a new fuel filter as that’s cheap and could fix the issue haha!
