Stock 80 Aluminium Bullbar with Winch?
Sydney, Australia
I have a 97 80 that I got as a second owner 6 years ago.
It has what I think is a stock aluminium bullbar on it (in Australia anyway).
Done a search but only found 1 post where someone asked the same question.
I'd like to know if anyone has been able to fit a winch to 80's with these bullbars?
If not these bullbars specifically, has anyone been able to fit a winch to a similar bullbar? And what did you have to do to cut a hole to feed the wire through and brace the winch assuming that you would need to bolt on directly to the frame/chasis rather than on to the bullbar itself.
I am handy with tools and welder but just want ideas on what sort of mounts people have done if feasible.
Tell me if it's a no go!!
Here's the pics:
Any Pictures ? Thickness of the face ? Pics of the bolts ? Space behind the face ? Which Winch ?
I have an Aussie Bullbar but I believe mine was designed to accomodate a winch.
Kalawang
Here are pics of the stock bull bar that we get in the Middle East! The winch is covered but it is there!
haven't got the winch yet.
I guess the fact that I can install it with this bullbar is going to determine which winch I get. But at the moment I've been thinking of something similar to this: from ebay
If there is some sort of winch plate out there that allow me to fit the winch behind the alloy bumper..
It's very very similar if not a copy cat of the TJM aluminum T-15 bullbar.
TJM has a specific steel bracket support kit to install a winch to their aluminum bullbar (steel model doesn't require aditional brackets), but of course it doesn't mean it will fit yours but shows it's possible to do it through TJM's design.
If I were you I would try to source a sketch of TJM's version and copy the idea as to make the steel parts to fit yours.
I saw a TJM brochure with the exploded winch kit parts description some time ago and that's why I remember.
The TJM kit is bolted to the two front ends of Toyota's boxed frame to which your Aluminum bull bar is fixed.
Measure the space between the rear face of your bullbar were the id plate is fixed and the front of the 80's body and the height between the inner upper face and inner lower face of the bullbar.
Deduct the gauge of the steel plate on which you will bolt the winch and that should gave you an idea of which winch could fit. You could fabricate a L shaped steel plate with left side and right side brackets, cut on it the square hole for the roller as required by the winch you choose, and once it fit well and tight the space behind the bullbar and can be bolted to the frame then you can cut the square hole for the roller on the bullbar. I suspect the hole is already there behind the ID plate. What I don't see is the top hole to access the winch clutch engage/disengage handle so you need to do it.
If it's Warn, a bigger than the 9000 lb model will not fit so forget about the 10,12 or 15K lb winch, and of course they can't be the i series, the relay box must be remotely installed inside the engine compartment.
ECB bull bars too...
East Coast Bull Bars have a winch kit/adapter that can be added... I had the non-winch one, but could have purchases the winch plate from ECB in Aussie land... but ended p going arb instead... totally doable... they mount to the bumper, ecb's web site shows an 80 winched off the ground with there's...
