Well after replacing my old dissy with one that has working advance, resetting baseline timing, and lean drop adjusting the idle mixture, I'm still having issues with idling. It idles great on start up, but when I clutch in after driving down the road it dies. It's bad enough that if I don't pull the choke or hand throttle out I have to run start it around turns. If I pull the choke out about 1/3 it'll stay running when I clutch in, then after 20-30 seconds I can let the choke off and it'll run rough but won't die, after 1-2 more minutes it'll smooth out and idle normally.
Any ideas?
I'm about out of patience with this truck. Every time I fix something, something else goes wrong.
Any ideas?
