I bought a Stihl MS460 with 20 in bar on Ebay and it does not seem to be oiling properly. I have gone through most of the posts on here and still having problems.
First problem is an Oregon chain which I will take care of on Monday and get a Stihl chain. The saw starts and runs fine but only spatters oil out of the oil slot with the chain and bar removed. Not enough seems to be coming out even though I have the adjustment screw on the bottom of the saw all the way to the right. I read where 8-18 cc of oil per minutes should be pumped through the hole.
I have drained the oil and checked the screen and what comes out of the hole is clean. Saw is not supposed to have many hours on it and it looks practically new. I have not tried to measure the volume of oil being delivered.
With the chain and bar installed I cannot detect any oil getting to the bar or chain. It does not spray or drip from the bar. It appears to come out of the hole but is not picked up by the bar or chain. I cleaned both holes on the bar and flipped it over with the same results.
Is the Oregon chain just not picking it up or is the oiler not pumping enough.
Any suggestion are appreciated.
Thanks!
Thanks!
