Our 2000 LX recently became hard to steer. It just takes more effort to make a turn and return the wheel to center. I have no idea where to start looking.
Do you know if your power steering fluid pump is in good condition? Also check the belt that drives the pump.Fluid is good. No leaks.
Jack up the front so the wheels are off the ground and with the car OFF turn your steering wheel from side to side then turn the car ON and do the same if the resistance is the same it's probably a bad fluid pump.Do you know if your power steering fluid pump is in good condition? Also check the belt that drives the pump.
Was it bright red or not? If not, a good flush with fresh ATF would help, along with pulling the reservoir off the pump and cleaning the screen. Oftentimes the screen is clogged and preventing sufficient fluid from reaching steering rack, which can make steering harder. Typically if the rack is bad, it’s going to make some racket (grinding etc).Fluid is good. No leaks.
