Stereo Help please! (1 Viewer)
Tennessee
Radio stuttering really quickly and already replaced the stereo head unit and that didn't fix it.
I wrote out a long post, then I realized that you posted a picture of a sound problem... there may be a better media format for sharing what you are experiencing.
Post one of them talky pictures to YouTube so that you can show my ears what stuttering is.
@KnoxLex Yeah need more information as to what you did, what you are using, etc. Usually audio clipping (stuttering) is caused by a malfunctioning head unit or an issue with another component that is attached (e.g. factory amp). So without knowing what you used and whatnot, its a crapshoot.
Wellll. Troubleshooting is all about eliminating possibilities. You may just have a bad chassis ground or you have a failing factory amp.
I'd check the connections to start. Definitely what's going to the power amp, maybe your head unit isn't sending a good power on signal to it?
I'd consider just bypassing the amp at that point - start with some temp wiring to test. Maybe grab a pair of cheap walmart speakers to test the head unit with.
