Steering Stabilizer removal
Finnally out of CA! Now in Bozeman, MT
Does anyone out there have any suggestions for removing the stock steering stabilizer (dampener) on a stock '85 FJ-60? I took of the bolts assuming it would just pull right off, but this is not the case. There are no visible pins holding it in either, and no matter what I try, the thing just wont budge. Does anyone have any suggestions?
thanks
-Zac
I got mine off with a big hammer and a little time. The bolts are tapered so they a PITA to get off, but saftey wise I suppose thats a good thing!
You need a big puller. I used a 3-ton craftsman (three prong) and it broke. Warrenty, thankyou very much. Upgraded to the 6 ton (also three prong) and was able to take it off. I used a long cheater bar though, and pulled as hard as I could. The noise when it "exploded" off was so loud my wife came outside to see what the "gunshot" was from!
what they said......
used a BFH to get one end off, had to use a puller to get the other end off. i was replacing my TRE's at the same time and was having trouble getting one end off so i soaked the bolt with PBblaster and cranked the puller down and let it sit while i was working on other stuff. when it finally separated, it sounded like an explosion. damn near made me spill my beer (and smack my head on the front diff.).
Yup, is a PITA. Try HEAT! A torch and a pickle fork worked for me. Be sure you grease the bushings on the new one.
hmmm ok
Thanks so much for your inputs. I just got home from work, but tomorrow i think i will try the big hammer idea, mainly because i don't have a puller. Hopefully it will work
not sure where you're located, but if you have Autozone in your area, you can "rent" pullers from them for free. worked for me.
got it off
well the big ol brass hammer and my blowtorch got the job done nicely. The new heavy duty stabilizer fit in, and works very nice. Thanks for your help
What stabilizer did you end up going with and where did you get it? I have to do the same here and was unsure about which one to go with...
I just went down to the ol' kragen and got a heavy duty Monroe direct replacement. It was about 25 bucks. It fits good, and makes a huge difference over a worn out stock one. :)
z-
what are you going to be doing in the Bozone? just moved from there. loved it. can't wait to get back someday.......
THAT I would like to see!!!!
phantom60 said:
z-
I am going to College at MSU, starting in late August. Can't wait! Montana is a great place. Know of any good trails for wheelin'? I have only done a few around the centennial valley, and that was last summer. :cheers:
I got mine off by shooting some kroil on it and I got a TRE Puller which is small, Tightened it down and left it over night, next day oiled it again and cranked it , it popped right out.
tclndcrz said:
zmontgomery- man this is awesome! i start at MSU in august too. we should definitely hook up and go wheelin.
Ohh right on! Yeah I can't wait to get out of southern CA. The LC's going to be loggin some miles this summer too since I will be driving out there twice. haha! :cheers:
i used a bfh to get the old one off and then bought one from asphincter because of the weird stud setup that goes through the eye, but next time, i'll just use a regular shock with a light rating and a shock stud in the oem mount to save $
i thought that wouldnt work well because normal shocks dont have the 50-50 dampenning ratio. with a normal shock used as a steering stabalizer wouldnt the truck absorb shock better one way or pull to one side? im really not sure...
