steering stabilizer removal
Discussion in '80-Series Tech' started by 410225, Feb 23, 2004.
  1. 410225
    410225
    230
    Sep 2, 2003
    Is it better to use pickle fork or the tie rod end separator? Or is there any other trick to removing this easily?
    Thanks.
  2. shocker
    shocker
    1,185
    2
    Apr 10, 2003
    Kansas City, MO
    Pickle fork and a BFH are what I used. You REALLY have to beat the hell out of it to get it off.
  3. Rogue
    Rogue
    969
    2
    Mar 27, 2003
    Jefferson
    Two-arm gear puller. Junk reccomended that to me a when I installed my lift (December 2002) and it has been one of my favorite little tools since.
    Watch out though for when it pops off. I still have a scar. :D
  4. Outback
    Outback
    606
    Sep 17, 2003
    Edmond, OK
    Yep, the two arm puller is far superior to a pickle fork. I hate pickle forks!!
    I just did this on my 80 and went after it with a pickle fork for about 30 minutes before going down to Autozone and renting a puller. Came back and had it off in 5 minutes.
    I'll never use a pickle fork again unless I just have to...
  5. PHAEDRUS
    PHAEDRUS
    2,036
    Mar 31, 2003
    pickle fork on an impact hammer will have it off in about 3 seconds. opposing that when we did rileys we used a little gear puller and it worked well but about 15 seconds to get it off.
    Dave
  6. Shortbus
    Shortbus
    204
    Aug 28, 2003
    Vancouver, WA.
    Haven't done this yet on my Cruiser, but I'd try heating the ends with a torch if you have one. Just did a set of exhaust bolts on a 150k mile car and heated them till they were glowing orange. Came off like butter.
  7. cruiserman
    cruiserman
    1,861
    Mar 27, 2003
    30 seconds with a tie rod end puller.
  8. robbie
    robbie Guest
    I do it routenly with a pickle fork, about 5 good hits and they pop. I use a mini 3 lb sledge called thor. works real good, jsut watch out for the lighting bolts. If using the pickle fork try not to have the handle too clost to the rod ends from the drag link, the fork handle can cut the boot on the rod end if you are not careful. robbie
  9. DanKunz
    DanKunz SILVER Star
    9,659
    Media:
    2
    Albums:
    1
    981
    Feb 7, 2002
    Woodstock, GA
    - Pickle fork and BFH
    - Torch followed by pickle fork and BFH
    - gear puller
    Third was easier, second was the most fun, first just made me sweaty and frustrated :beer:
  10. concretejungle
    concretejungle SILVER Star
    9,511
    727
    Oct 27, 2003
    North Cadillac
    i thought changing out the steering stabilizer was a waste of time and money. ::) I used a pickle fork, but didn't notice a bit of difference before and after.
    Did you all have a heck of a time tightening down the OME stabilizer? I don't know why but when bolting up the new one i had to literaly get a pipe extension on my wrench and use the tire and my legs to torque her down. :-\ Really tight.
    :beer:
  11. PHAEDRUS
    PHAEDRUS
    2,036
    Mar 31, 2003
    no problems on mine. just a 2' torque wrench set to 90lbs of force. Of course on the ps mount I took the bracket off the truck and did it on a vice then replaced the two mount bolts with some new grade 8 s. all told took me about 25 minutes including breaking off one of the mount bolts when I went to tighten it up. Some days I love working for a dealership they have all the cool tools just sitting in a room.
    Dave
  12. Cruisin'Carolina
    Cruisin'Carolina
    1,434
    8
    Dec 11, 2004
    The Rock
    i think i just stripped the bolt....have 1/2" of thread showing, then it just got easy....i was only using an 18" ratchet:doh:
    Now what?:doh:
