Searching has brought up a lot of info for me, but I need some specific advice. The front ends of these trucks have a lot of parts that can affect steering.
My steering is not terrible, but I want to make it better.
I have a 2 year old OME 2.5 lift. The truck tracks straight -stops straight. It clunks when doing slow speed parking manouevres and it has started to clunk every time I turn on the highway (just once as I start the turn.)
The clunking I just mention as a symptom - they all clunk and I am not super concerned about the clunk itself. (I suspect spring pack shifting)
What I am more concerned about is the tendency of the truck to wander while in the midst of a turn. It makes driving winding mountain highways a little nerve wracking.
I have had the alignment checked - toe in is fine. My caster angle is 1.2 deg on the left and .6 deg on the right. (a little mismatched)
The Drag links are backed off 1/2 turn from tight.
The TREs are within spec.
The steering box is correctly setup.
the steering shaft u-joints are tight - I have not greased the splines.
I have not done the knuckles, they spill a little grease, but the tires don't clunk when I pull at 12 oclock on the tire. The front hubs DO get quite warm while driving - I don't know whether this is normal or not. (and it's not connected to brake use - the hubs will be warm and the discs cool)
So with that as background, my questions are
- do warm aisin hubs mean bad things?
- what is the most likely culprit for the uncertain turning - knuckles or caster angle? Or something else I've overlooked?
Thanks in advance for your ideas!
