Steering shaft firewall seal question
Discussion in '80-Series Tech' started by LandCruiserPhil, Mar 10, 2004.
  1. LandCruiserPhil
    LandCruiserPhil Peter Pan Syndrome Supporting Vendor
    21,674
    Media:
    55
    Albums:
    3
    12,316
    Mar 10, 2004
    Scottsdale Arizona
    Hi all, New to the forum due to a recently purchased a sweet 96 FZJ80 with lots of goodies. One of the few things that need attention is where the steering shaft passes threw the firewall. Visually all there is about a 1 ½ hole with the shaft floating around in it. I can only assume this is not right. Any insight would be appreciated.
    Phil
  2. Darwood
    Darwood
    1,957
    8
    Oct 8, 2003
    Z.O.W.I.E. Headquarters
    I noticed this as well and have been meaning to ask about it. I doesn't seem right, but then again if we both have it...
  3. ppc
    ppc M Go Blue
    2,058
    608
    Aug 18, 2003
    Nashville, TN
    Make that a third.
  4. cruiserdan
    cruiserdan SupportingVendor Emeritus Moderator
    22,323
    6,636
    Mar 27, 2003
    Land Cruiser Heritage Museum broom closet
    There is a seal in the toe panel for the shaft. It happens to be the same part number as the early 90's trucks use. The number escapes me at the moment but I recall it to be less than 10 bucks. The fun part is pulling the colunm to replace it.
    Oh, mine could use one too. :doh:
  5. LandCruiserPhil
    21,674
    Media:
    55
    Albums:
    3
    12,316
    Mar 10, 2004
    Scottsdale Arizona
    Is the seal of a heavy enough designed to stabilize the shaft.
    If its just a "rubber thing" seems like modification is in order when you look at the fun in changing it.
    Phil
  6. Darwood
    Darwood
    1,957
    8
    Oct 8, 2003
    So do these seals just wear out overtime? Will replacing it fix the gap?
  7. T Y L E R
    T Y L E R
    2,597
    5
    Mar 27, 2003
    [glow=black,2,2]Spray on expanding foam looks pretty good right now eh ? ;)[/glow]
    [color=555555]T[/color][color=2E3136]T[/color][color=555555]Y[/color][color=2E3136]Y[/color][color=555555]L[/color][color=2E3136]L[/color][color=555555]E[/color][color=2E3136]E[/color][color=555555]R[/color][color=2E3136]R[/color]
  8. the shed guy
    the shed guy
    624
    Sep 8, 2003
    DOWN UNDER
    Cut the new seal with a really sharp blade for a nice clean cut, and then superglue the seal cut edges back once around the shaft, save pulling the steering shaft out.
    I have done this with swivel hub seals as well, when I havent needed to pull the whole swivel hub down.
  9. robbie
    robbie Guest
    did one of these for a customer the other day and it was real easy. only took me about 40 mins with doing it twice(funny). Just remove the shield above the steering coloum down by the steering box and then go under the steering and remove the two bolts at the end of the steering wheel. remove the two bolts holding the gasket in place on the fire wall and it will slide out. Remove the coupler from the steering wheel end of the shaft and slide off old gasket, slide on new one (right way, this was what lead to the second time). next is reversal of removal. all is good should only take 30 minutes tops. later robbie
