I used the $$$ Red line grease before, and it separated a lot in the container, I tossed it and used Valvoline. My Valvoline grease has not separated in years.
All you need to do to check if your knuckles are leaking is pop off the cap at the end of knuckle. If its leaking, the birf soup will be there. You can also go one step further and take the drive flange off. You will see the soup if its leaking. From the pictures, I'm pretty sure they are leaking.
Did you use OEM seals??? Did you check the bronze bushings for wear??
