Steering knuckle bearings
Discussion in '40- & 55-Series Tech' started by tewlman, Feb 10, 2004.
  1. tewlman
    tewlman
    340
    8
    Nov 24, 2003
    I need new knuckle bearings, the old ones are KOYO 30303D.
    ordered new ones from parts house, they are NTN 4T 30303.
    the taper on the rollers is different, will these work or should I get some from SOR? ???
  2. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,304
    Media:
    17
    Albums:
    1
    618
    Oct 1, 2003
    MN
    Replace the cone and the cup together, and you should be fine....but what 'parts house' did these come from?
  3. tewlman
    tewlman
    340
    8
    Nov 24, 2003
    I knew i could count on your vast knowledge steve.
    big A auto, right across the street from my shop, I like to do business locally(small town guy)
    I found what looks like the correct bearing on www.cruiserparts.com, they are cheaper, so I might take these back.
    steve
  4. Poser
    20,304
    Media:
    17
    Albums:
    1
    618
    Oct 1, 2003
    MN
    Did you get the cone and the cup, or just the cone?
    And I think that the only thing that is vast is my ass....
  5. tewlman
    tewlman
    340
    8
    Nov 24, 2003
    a really don't want to see your ass, and yes I got the cup and cone.
  6. Poser
    20,304
    Media:
    17
    Albums:
    1
    618
    Oct 1, 2003
    MN
    If the race is the same OD as the one you knock out, and the cone ID is the same as the one you took off, as long as there is not a massive height difference between the two, they should work fine.
    Do you still have an old cup and cone?
    If so, set the cone in the cup, and compare that to the new one...
    Above all, if you are not comfortable with what you have, do not use it.
    I have not found an aftermarket bearing that has the identical taper, and number of rollers as the Toyota bearings, but I have not broke out my bearing interechage book yet either, which is where I am headed..
  7. tewlman
    tewlman
    340
    8
    Nov 24, 2003
    I wait in anticipation....
  8. Poser
    20,304
    Media:
    17
    Albums:
    1
    618
    Oct 1, 2003
    MN
    IBI(international bearing interchange) calles out the '30303' as a group 40031 bearing cone and cup.
    In the multiple manufacture's listed, Toyota appears with the old part number of 90366-17011, which has changed to 90366-17011-77.
    I would not have a problem going with the bearings that you have, going off this information, again however, if you are not comfortable using them, then I would not.
    Good luck!
    -Steve
  9. Poser
    20,304
    Media:
    17
    Albums:
    1
    618
    Oct 1, 2003
    MN
    All group 40031 bearings are:
    0.6693 in ID 17.00mm
    1.8504 in OD 47.00mm
    0.6103 in W 15.50mm
    Good luck!
    -Steve
  10. Blue60
    Blue60
    606
    3
    Mar 16, 2003
    Jeeezum Poser...you're way better than the "Shell Answer Man" every dared dream of being. When I get serious into my frame off on the 79 I'm going to have to throw some questions your way!
    Cheers, and keep on Cruising!
    Blue60
  11. Poser
    20,304
    Media:
    17
    Albums:
    1
    618
    Oct 1, 2003
    MN
    Thanks Blue60...
    I am really not that smart....there are many out here that have done a lot more than me...
    Good luck!
    -Steve
  12. cavsfj40
    cavsfj40
    194
    Apr 16, 2003
    i'd like to break into the parts store and steal all the parts books. the guys there cant read them anyways. then i would be able to find everything that i wanted
  13. Cruiser_Nerd
    Cruiser_Nerd That 25 Guy. Moderator
    4,221
    140
    Dec 3, 2002
    Higganum.
    Hate to say it, but you might want to do a search on the LCML archives, it's been a topic of debate for years.
    I'm looking at a TSB right now dated 7/21/59 stating that the knuckle bearing was changed from a 21 degree 30 minute outside taper to a 57 degree outside taper to "provide increased durability to the bearing". From that I would assume that the flatter bearing is better.
