How the hell do I get the old Steering Stabilizer off? I swear to God it is stuck I have beat on it and everything it will not come off. Is there an easy way or any way to get this thing off?????????
I just replaced the stock steering stabilizer on my FJ60 and had a similar problem. Pounding did not work. Don't use a pickle fork as it will cause other problems. Use a small or medium tie rod puller. It is U shaped with the top of the U returned in. Worked Like a charm. You can rent the puller from NAPA or do what I did and by a set of pullers with the one I needed in it.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
