- Thread starter
- #21
That is such a cool look.View attachment 1946069
Here's the 16x8 on my 40
No that is a poser shotIs that when you almost rolled it?
An 8" rom is standard with 4" backspace so that would be 0 offsetIsn’t a factory 16” alloy wheel zero offset? What is the offset on those steel 16’s? Just guessing here but they should work with spacers (Bora’s are available in 1/4” increments starting at 3/4”) and some 255/85’s. Would look pretty cool, IMO.
Yep they don’t have the clipsAren't OEM steelies available any more for 80 series or is it just that they don't have the center caps compatibility that takes them off the list?
They are made by Wheel VintiquesI saw the smoothie, I think cragar makes them.
Do you have any pics? I’m not following the pairing of the 40 with the smoothie.
Offset is all wrong for an 80. Flex uses Dean Cross Country alloys, which would be cheaper to order from Japan then having a company modify OEM's. Much lighter too
None that I'm aware of, but would recommend:Do you know of a USA retailer?
If I could do it I would in a second. They emailed me back saying that they don’t work.Just put spacers on the city racer wheels, slap some caps on and call it done.
I didn’t ask them about spacers, here is the reply. Roger didn’t make any suggestions other than a place called Stockton wheels.They said that spacers won’t work with their wheels? Sorry, but that’s bulls***.
First of all, his response tells me that he’s a business man and simply covering his ass for people who don’t know what they’re doing. If you know what you’re doing or can figure it out, disregard.
The vehicle doesn’t care how wide the wheels are (be reasonable, as long as you aren’t on extreme ends of the spectrum you’ll be fine). Tires do have recommended wheel widths but I’d be willing to bet that most guys on this forum are running tires that are technicallly too wide for their wheels with zero issues. On another project of mine I have 9.50’s on super skinny 4.5” wheels and it’s perfectly fine. A couple different friends of mine have 33x10.50’s on 15” 40 series wheels (one FJ60, one FJ40) and they’re all good as well. They don’t handle great but they’re not meant to either.
It’s up to you, if it was me I wouldn’t hesitate to do it. What size tires you want to run? The 255/85’s sound good to me but I would research more before purchasing. Bolt them up and see how much (if any) it needs to be spaced out. This isn’t rocket surgery
In a previous life I heard a lot more negative experiences with Stockton Wheel than positive ones. Maybe they’ve changed, maybe not. But he brings up a good point, you really wanted to you could have the city racer wheel centers welded to wider barrels, that would solve everything. Maybe you could order just the centers to save cost.
I think it’s a cool idea, don’t give up on it. Good luck.
looking at trying to get the 305 ko2’s with a 2” ome lift. The 285’s are second.
Trying to buy the centers only is a great idea.
I
