Wanted Steel Rim ( Central US )
S. WI
Looking for one welded original steel rim with clips. Hope to find one located in Central US.
steel wheel
Is this what you're looking for. Hard to tell in the pics, but it's all surface rust - wheel is solid. Let me know if you're interested. No idea what it's worth, you tell me.
jad
Hi John
This appears to be from the early FJ ( pre 1976) that did not have disc brakes up front. The rivets holding the center disc to the outer rim are the indicator for that. I need the rim 1976 on that was only welded together and thus indicating they had clearance for the discs. If you have one that is only welded together I would be interested.
bump for the weekend
JohnB, That looks like it, how much and where in MN are you? PM sent
Kevin
