I've been running a carpet cleaning business for 19 years and have always run a propane burner 180,000 BTU's to heat my water. When it comes to high pressure cleaning (like a greasy undercarriage) imo it takes a minimum of 180,000+ BTU's to create heat that is sustainable. Anything less and you will peak at a max temp then quickly cool down. A diesel / kerosene burner is ideal. Anything less will leave you frustrated with lack of performance / results. just my .02 cents.
I've used it and wanted a different style with a separate reservoir. I need something with a small onboard pump, if such thing even exists.Have you talked to Dad about his steam cleaner? He's using a cheap one, but it's done great on some engines and stuff. Just slow. I wish I had a bigger one.
Dan
