This may be premature but I might be taking a government job in the next few months. I need to know how to rank my location preferences. My question is this, what states have the easiest inspections and would allow me to keep my 62 4bt ?
Here's what I have so far:
ALABAMA: No inspections
ARIZONA: is cool with tons of places to play.(waiting on definition of "cool")
KOMIFORNIA: too expensive and too much traffic. but here are the rules:
Engine changes are legal as long as the following requirements are met to ensure that the change does not increase pollution from the vehicle:
GEORGIA: No inspection outside of Atlanta and surrounding area
ILLINOIS: Illinois does not require smog checks for vehicles pre 1996 (OBDII). You can do whatever you want to the engine.
INDIANA: No smog or inspections.
KANSAS: No inspection, no place to wheel.
MONTANA: There is no required smog check (emissions testing) in Montana.
An annual safety inspection for vehicle registration is also not required. Maintaining your vehicle is your responsibility
NEW HAMPSHIRE: too cold,salt on road, rust receipe but no emissions only safety inspection
NORTH CAROLINA: if your truck is titled /registered as a diesel already and you can transfer the title / registration into NC as a diesel, you're golden. All you have to pass for a 62 is the safety inspection, which includes brakes, lights, horn, etc.
If you transfer your truck with a gas title / registration into NC, you get one free year, in which you will need to go through a not-so-difficult process to get the registration changed over to diesel. I can give you all the forms and details if needed.
OHIO: No emissions or inspections and two hours from wheeling.
OREGON: Emissions only in Portland and Medford, but don't have room for one more
TEXAS: Safety inspection only, no emissions test
UTAH: Yearly smoke test and conversion title
WASHINGTON: most counties have no emissions testing, and large parts of King County (the big one that Seattle is in) don't have testing, and even in the areas WITH testing, the following are exempt:
- 25+ years old
- Diesel under 6000 lbs GVWR and older than 2007 (and even an 80-series has a rating under 6000 pounds)
WYOMING: WY, NO Emissions or vehicle inspections and NO state income tax as well.
Feel free to let me know if I miss anything as I compile the list.
- The engine must be the same year or newer than the vehicle.
- The engine must be from the same type of vehicle (passenger car, light-duty truck, heavy-duty truck, etc.) based on gross vehicle weight.
- If the vehicle is a California certified vehicle then the engine must also be a California certified engine.
- All emissions control equipment must remain on the installed engine.
- 25+ years old
