So now that my '96 80-series is not my daily driver, I'm starting to plan out a diesel swap for it. Its stock 1FZ-FE is still running reasonably strong at 213k miles (leaks a fair bit of oil from various seals, but otherwise ok), so I'm not in a hurry and am planning to spend plenty of time overhauling whatever engine and parts I get before ever tearing the 80 down. Here are my current thoughts, and anyone is welcome to drop some knowledge/experience on the topic.
Engine: Cummins ISB3.9 170hp (newer version of the 4BT), or Isuzu 4BD1T or 4BD2TC
Reasoning:
While my first choice would be a 1HD-T or FT swap, I don't want to spend that much and don't want to deal with the challenge of finding parts down the road. While the simplicity of the mechanical 4BT is nice, I don't want to deal with the noise and vibration, and several people on the forum have noticed that 4BT swaps tend to be sold shortly after completion because the noise and vibration are just too bad.
ISB3.9 Pros: Newer engine, more power, more efficient, electronically controlled but still relatively simple via built-in ECU, common rail injection, rear gear set (reduces vibration), quieter, about 100 lbs lighter than a 4BT.
ISB3.9 Cons: More expensive than mech 4BT (though still far less than a 1HD), little-to-no info regarding 80-series swaps, the rear gear train makes fitment more unknown, and transmission/t-case compatibility questions (see trans section)
4BD1T or 2TC Pros/Cons: No idea yet, as I don't know that much about the engine yet.
Transmission:
This is where things get interesting. My '96 has the A343F transmission with the TCU integrated into the ECU, so I'll either have to shell out for a stand-alone TCU (which I'd rather not do), or change transmissions. The easiest solution from the T-case perspective is to swap to an A440F from a 91-92 80-series, but then there's still the question of the engine-side of the bellhousing. The ISB3.9 comes with either SAE 2 or SAE 3 bellhousing, and is usually mated to an Allison 1000 5 or 6 speed auto.
From what I've read, the Allison 1000 is a fairly solid transmission, that double-overdrive (0.61 6th gear) sure would be nice for highway RPM, and it's already very compatible with the ISB3.9, but I have no idea if it would even fit in the transmission tunnel (even with some hammering) and I'd either need a custom-fabbed t-case adapter, or go to an aftermarket t-case (again, expensive and not sure if there are options).
While I'd like to keep it auto, I'm not totally shutting out the idea of switching to manual if it greatly simplifies things. It looks like it might be possible to adapt an NV4500, but would require custom adapters or machining an SAE #3 bellhousing.
There are a lot of variables to the equation, and I'm going to start calling some shops (Jonesy's Offroad, Advance Adapters, etc.) to get ideas on what they think may be feasible.
Reasoning:
Transmission:
