Starting the 1hdt after the BEB change
Calgary Alberta Canada
anything I should know about this!! start the vehicle as normal!! Help again.. thanks
If you put the bearings in with some sort of assembly lube it should be fine.
If you want to be extra safe then pull the lead to the fuel solenoid and crank the engine over with the starter till you see oil pressure building on your gauge. Then plug it back in and fire it up.
thanks... I did use a lube so I should be safe.. thanks again..
