So about a year ago I purchased an 05 Yukon Denali, the LQ9 in it had low oil pressure. Luckily there was no damage to anything internally and everything was close to factory spec numbers. So new a new oil pump, rings and bearing went in and I put her back together. I went through the 4L65E as well and installed aftermarket clutches and a shift kit. So now I have a fresh engine and trans ready to go in my 80. I am pretty mechanically inclined and did a swap on my 73 FJ40 8 years ago.
Exhaust:
I am in California and I am planning on do the swap and keeping it legal for the road and smog. This mean I need to keep the factory headers. Has anyone on here done this? I know most of you end up just using block huggers.
Engine Mounts:
I have also seen a handful of different engine mounts being use. Has anyone successfully fabed their own engine mounts using the factory Toyota mounting locations? I am not sure if this will make the engine sit higher than it should or not.
I know I can use the search function to find other thread(and I have) but if any of you have any suggestions or comments on things that you would have done differently that would be appreciated as well. I am never against learning from my own mistakes. But I prefer to take advantage anytime I can learn from someone else's first.
Exhaust:
Engine Mounts:
