So, I have two starters, both in good condition. The original Toyota starter has had a rebuilt contacts and plunger, worked fine afterwards. Then, the mystery started...
First, the car wouldn't start. Moving the gear shift back and forth, it started again. Assumed I had a bad switch contact in park. Local Cruiser guy tightened up everything, and things seemed to work great after that....until...
Went to start it again, and all of the lights inside dimmed (clock went almost dark). Moved gear shift several times, still no start. Came out the next day, started up fine.
Any recommendations on troubleshooting an intermittent starting problem? I was wondering about all of the fuse looking connections near the starter, could there be a loose connection somewhere?
