starter contacts, which to get
Boulder, CO
Need to replace the starter contacts, but how do you know which set to buy...the 2.0 kW or the 1.4 kW before you take the starter off?
Your starter should have a label plate that tells you what type of starter you have. Check the plate first and investigate to see if you have 2.0 or 1.4
I can't remember how I got the correct ones. I just called Dan and I got the right parts.
Or if you're like I-Doug, just check your sig line. :D
thanks..figured it out by the starter part number
