- Thread starter
- #1
Hey all,
Just reinstalled my tie rod tonight after converting my 75 FJ40 to FJ60 knuckles.
I pressed starter bushings (part number SB0) into the FJ60 steering arms to make them work with the FJ40 tie rod ends.
However, it looks like they didn't cut it - fully tightened, the hole for the cotter pin still sits well above the castlations on the castle nut...same on both sides...
Sorry for the dark pictures:
Is this normal? What are my options? I'd like to avoid running a washer on top of the steering arm, but I've seen that done...
Also - looks like the boot on one end is damaged from a bad alignment or a backspacing issue on the wheel:
As you can see, it's bleeding grease. Are replacement boots available for these? (555 TREs from Kurt)
