I'm trying to deal with my saggy rear springs and don't especially want to lift as i don't really want to get involved with rectifying caster etc.
Easy answer would be some OME low lift springs, but unfortunately there are a few complexities involved which i'm struggling with.
Vehicle in question is a 1991 hdj81 with a factory electric winch at the front end, factory tyre carrier at the back and maybe 50kg's constant load in the back. Tyres are 295's, but i'm not sure that matters. Looking at the parts catalogue, models fitted with a winch got different springs up front, however the bit i'm struggling with is that spring manufacturers, e.g ironman, king, dobinsons state that pre 08/91 80's will get 20mm less lift when changing springs than later models. unfortunately, it is not stated whether this is due to different springs being used before 08/91 or whether the spring perches changed (i've emailed ironman regarding this, but not received any response yet).
At the moment i'm left with a bit of a guessing game with regards to what springs to get. if i get 'stock height' ones i might end up no better than where i am now, on the assumption that the perches are different. If i get more the more common 2" i may end up higher than i want if the original difference was due to a change in spring type in 08/91.
looking at old threads (i think i've now been through just about all of them), it seems they rolled out of the factory with approx 20.5" between hub centre and flare and so should have sagged a bit after 20 years. My measurements below show not really any sag at the front and a fair bit at the back. as a guide, i cant get my fingers between the bump stop (the one inside the spring) and perch at the back, its pretty much rolling on the bump stops.
front:
left - 20.5", 515mm (320mm from bottom to top of spring)
right - 20.9" , 530mm (320mm from bottom to top of spring)
would appreciate any thoughts on how this compares to post 91 trucks or any guesses as to where the 20mm difference alluded to by the spring manufacturers comes from.
If included a few pics, which may or may not be of any help.
thanks
callum
rear
left - 19.5", 495mm (270mm from bottom to top of spring)
right - 19.25", 490mm (270mm from top to bottom of spring)
front:
thanks
callum
rear
