My '98 has been having stalling issues for the past year or so that began to occur rarely and has recently gotten worse. It will drive and shift fine but whenever I attempt to accelerate hard (foot to the floor) it stalls out, and the second I let off the gas it returns to normal. I have also had some rough starts recently as well. There are no check engine lights, and does not appear to correlate with engine or outside temperature. I also have some odd smells after longer trips, not sure if related or not.
So far I have: replaced air filter, load tested alternator, cleaned MAF and throttle body, replaced fuel pump and filter, and ran injector cleaner with a full tank of 93. None of these have had an effect so I am beginning to believe this is an electrical or transmission issue. I've heard about the early 100s having EFI fuse issues, so I checked the fuse and connectors in the block and everything looked fine to me. I am planning on doing a trans fluid flush as I'm sure the fluid is nasty and old this week.
Anyway, I'm pretty stumped at this point and not sure what to do next. Would like to avoid throwing more parts and money at a problem that I keep misdiagnosing so curious if anyone has any insight on where I should go from here. Thanks
