Stainless Steel Braided Clutch Hose (1 Viewer)
shipmag
Hagler Technology LLC. Aka Shipmag
Cape Girardeau Missouri
For those interested I am looking at developing a Stainless Steel Braided hose. The construction will be the same quality as my Transmission Transfer Case Bypass hoses.
My hose vendor has the male and female M10 fittings. He does not have the M11 threads. If there is a large enough request I can get them made. The M10 female fitting would not have the groove in the fitting to be able to use the oem clip holding it tightly in the existing bracket. We may be able to use a press on clip.
I do not have a landcruiser with me. So I would need some help getting the hose design that would be except-able to all. After all this is how we originally developed the bypass hoses for the FJ60 was other mudders helping with the design.
Can any one send me a pick of the tube fitting going into the female fitting of the hose?
Btw my bendors 10mm female bulkhead fitting has the groove.. once we confirm the type of flare on the tube ill make one.
Braided stainless steel clutch hose?
Thanks but i already have one.
Plus, mines for a 55. 40s are probably different.
IIRC, hose ends were the same as brake lines
