SR with OME pics?
newport RI
last time I asked a question I got excellent answers so hopefully I will get some good ones this time as well.
I am looking to fit 35's under my fj62 and have an OME heavy suspension which offers 3" or so of lift and I don't want to go SOA. I just want another 1" to 1.5". A body lift would be alright except all the body armor i have on it would have to be redone. While I don't mind putting extended shackles on the rear, I don't want to put them on the front.
So i am looking at going the SR in the front and extended shackles in the rear route. I am looking for pictures/write ups (besides the one in the tech section of people who have done a Shackle reversal with a OME or like lift. not using the Man-a-fre kit (too much lift)but doing a custom job.
if the SR is not a viable option my next plan is to have to 4-5" Alcans made up, but want to see whats been done on the shackle reversal route first.
Jason
Just curious, why no shackles up front?
with the OME shackles I am already an inch over stock in the shackle department. Plus I did it on my fj40 and really did not like how it handled. granted it's a different cruiser, longer wheel base, ect. but it still left a bad taste in my mouth.
Jason
Did you correct the camber on the 40 with a shackle lift that had the bad handling?
Bad camber = bad handling. Sometimes it's as easy as a $12 pair of camber correction shims.
If not, then I'd suggest that was your problem.
This was listed on ebay awhile back and I grabbed the photo.. nice looking ride.
OME Heavy suspension SUA with a MAF Shackle Reversal kit & 33"x9.5" BFG's
yeah I corrected with caster shims. Its just not the direction I want to go in (at the moment) I am not saying it is a bad way to go, just not for me. I would rather go the Alcan spring route. But I wanted to see if anyone had done the SR route without going SOA first.
Jason
Here is a picture of my old rig, I sold it to my roomate.
http://www.aseif007.net/grey_cruiser.html?1097104643823
What you see there is an 88' FJ-62 with the OME petrol heavy springs in the rear, and the mediums up front. I ran that setup with 33X10.50 for about 60,000 miles. I then added the reversal in front to clear 35s. Then for the rears I needed to level it out and allow the springs to travel out longer so I added the 2" over stock anti-inversion shackles in the rear. That is what you see in the picture, and with what you see in the picture I put on 35s(I have a picture of the 35s but I can;t find it, I will post it if I do) I have the OME diesel heavy add-a-leaves, that aren't installed yet, and that should level out the rear even more. Hope that helps.
Andrew
88' FJ-62
97' FZJ-80
01' TRD Tacoma
Not sure what you mean by the MAF SR giving too much lift, its just what you need(lift wise) 1.5" at least my fj45 with MAF SR thats what it came out as. I like the MAF(Dave Gore) kit.
I have seen the Man-a-fre kit. and that might be the way I go but I wanted to see if anyone had done a SR differently that's all.
but from the kits I have seen installed it seemed it was more like 2"+ of lift and i not sure I want to equal that out with that long a shackle in the rear.
upon looking at the Man-a-fre web site it seems they sell the kit in conjunction with OME so I am glad I have now seen some pics of it installed because the some of the others I have seen with the kit seemed to have a nose high rack to the stance, which i want to stay away from. if that makes sense
JAson
this is a local 60 with a homemade SR, Win did it himself back the 80's sometime!, he bought the 60 new and its just the same now as back in the day, cept now it has like 1 million miles on it......tows a 26ft boat to BC sometimes. Best pics I have of it.
this is one of the Cruisers that made me want a Cruiser.
Jason, did you ever consider doin a SR in the front, shackles in the rear and puttin in an add a leaf in the rear if you didn't like the stance. Might be somethin to look into.
that is exactly what I am trying to get pictures of but I know how much trouble Spence had with his kit so I just wanted to see what others have done by fabbing there own kits. what are you going to do for a SR? I already added the heavy leaf to my OME's after last years fall gathering and it gave me an inch and a half that settle quickly down to half and inch of lift. so anymore lift with these rear springs will have to be shackles alone.
Jason
Funny, I am in almost the same situation. I have OME Meds in ft and HDs in back with 2" over shackles all around. I clear 35"s pretty well.
The Alcan idea is a good one but very arched springs have their own issues also. Devo in Denver has 4" alcans on his 60 with 1" over shackles all around. He runs 33"s but could easily run 35"s. You will lose a lot of flex.
The SR will work well for your application but for the PITA factor I would just go with shackles and shims.
Another idea would be SR in front and SOA in back. Easy way to level the truck, avoid shims etc...The main issue will be finding a spring pack that has enough spring rate to support the truck and also not be so high you end up ass up!
fj6202840
If you are worried about the installation of MAF's shackle reversal you shouldn;t be. It is pretty straight forward, and if you can weld it is a piece of cake. You can;t mount the brackets wrong since they bolt onto the frame where your 4 bumper mount bolts are rivetted in. The only thing I didn;t know before installation was that I had to leave on the plate that is in between the factory spring perches and the frame. When I cut off my front perches I also grinded off those plates. Well when I went to fit the reversal brackets there was a ~1/8" or so gap between the bottom of the frame and the SR bracket. I cut up some scrap metal and welded the brackets on, no big deal. The link I provided in my last post is a picture of the reversal and the OME mediums in the front., and the extended shackles in the rear with the OME heavies (no diesel add-a-leafs in the picture yet). If yo uare worried about the welding don;t be. You can put 5 grade 8 or higher bolts into the bracketry, then carefully drive to a welding shop and have it done. I drove around with c=clamps and 4 bolts to test it out and it was fine. But I don;lt reccomend doing that for too long.
Andrew
No I am leaning toward the Man-a-fre kit it hit me today that on none of the ones installed that I have seen has a winch mounted, which would definately bring the nose down alittle. which is prolly why my cruiser rides nose down, a look I like and want to keep.
Man-a-fre seems to be the only ones that offer a kit for the fj6x and while I have had both good and bad transactions with Man-a-fre i wanted to know and see what else has been done/fabbed and is on the market.
they seem to design there kit around a OME lift which is what I have and really like, so that is a deffinate plus.
thank you Rev Doctor and Andrew and Godhead for posting the various pics of SR fj6x's
Jason
jason... provided this doesn't f* with my driveshaft too much i am doing this mod on the 19th of feb. with spencer actually. then, i will do the same rodger brown 1" body lift you have. i will post pics here and keep the thread going...
man-a-free. going to order it today. also going to get whatever anti-inversion greasable shackles they have for the rear to level it out.
after the 19th, when the S/R goes in. I will head back down there to get the rodger brown 1" body lift on. then the next step is to get 34x12.5 Trxus on rock crawler rims (3.25") with some .25" wheel spacers just in case.
i want to have it all done by march. hopefully when the snow starts to melt so we can get out there!
how close are you to having solid 4wd and your 35s on?
the elocker is in the front but not wired up yet. i have a fzj80 swithc on order for a nice clean factory look on the dash. i ordered another 4 16x8 5.25 backspaced wheels to match the rear wheels on the fzj80 axle. so i should have everything but the tires on by the end of the month. I am leaning for 315r16 goodyear mtr's which measure in at 34.8" or so so it will between a 34" and a 35" tire.
will seel how it works out.
jason
