Video here
About a month or so ago I was under my LX re-installing the rear prop shaft after having a shop install new u-joints. While I was under there spinning the rear wheel to get access to the bolts I noticed a squeal. This sound was not present during the removal of the shaft. Sounded like it was coming from the rear diff?
Fast forward to today I was getting coffee after work and as I was turning through the drive through I hear the sound but it's the loudest it's been. Since then I have replaced the rear diff oil with Valvoline 75w90 Synthetic with LSD additive. Sound was there BEFORE and AFTER the diff fluid change. It seems to only happen driving forward. I back in to my driveway so I will usually hear it when I drive out. About two weeks ago I tried to isolate the issue by jacking up the the rear and turning the wheel by hand. No noise.
Some possibly relevant info....
At one point during the replacement of the prop shaft I had the rear end slightly lifted (few pumps of the floor jack under the rear diff, tires still on the ground). Forgot about this and went to change garage stalls and drove forward while still on the jack. The jack tipped and the truck fell on the jack, on the rear sway bar. The jack was tilted at an angle but it definitely put some weight on the sway bar. It was after this that I noticed the noise.
Really appreciate any input. Hoping I didn't ruin something by driving off the jack like that.
