squeal, smoke, no starty
Discussion in '60-Series Wagons' started by patride71, Jul 2, 2005.
  1. patride71
    patride71
    1,483
    91
    May 8, 2004
    Austin & Alpine, Texas
    drove the 60 yesterday and it started making a slight squealing like a belt was slipping. today started it and it really started squealing and smoking and now it won't start at all. it just squeals when i try to start it. it has been desmogged, so that would not be it. one belt looks a bit worn. others look ok. alternator is new. crankshaft pulley is new. everything else, i don't know. best place to start, or most likely culprit?
    tia,
    pat
  2. Landpimp
    Landpimp
    16,093
    Media:
    1
    2,078
    Mar 14, 2003
    Gig Harbor WA
    water pump seezed up?
  3. swank60
    swank60
    1,484
    244
    Aug 26, 2002
    One of Four Presidential Flying Saucers
    Does the motor turn over with the starter? Have you looked under the hood while it was being turned over, or tried to turn some of your extra junk by hand?
    Could be isolated, too. There's a chance you could have blown that fusable link again, and that your water pump is shot, too.
    Aren't you glad you didn't sell that f'ing thing now?!?!
  4. patride71
    patride71
    1,483
    91
    May 8, 2004
    motor does turn over with the starter, but the squealing starts right away.
    i tried to turn some stuff by hand, but not much success. i was thinking water pump too, but exactly how do i tell?
    yeah i am so glad i kept this thing :rolleyes:
    gumby drives it 1100 miles down here with no problems and i've driven it probably 10 miles and this happens.... :mad:
  5. lovetoski
    lovetoski SILVER Star
    4,618
    288
    Jul 13, 2003
    Remove the belt (s). Then you can turn everything by hand. Should also be able to start it and run it briefly with no belts. (Not long though as the waterpump won't be working.) If you remove the belts, and it runs with no squeel - then it's something that a belt connects too...
  6. LoneRanger
    LoneRanger
    3,082
    Media:
    1
    Albums:
    1
    152
    Mar 15, 2005
    on stage
    I had a squeal recently. It turned out to be the AC compressor. I just detatched it. No squeel now. AC didn't work anyway.
  7. FJ40Jim
    FJ40Jim The Cruiser Whisperer SILVER Star
    10,352
    Media:
    1
    2,731
    Sep 26, 2003
    Lancaster, Ohio, USA
    What about the air pump? That seems to be the most common seized accessory.
  8. zebrabeefj40
    zebrabeefj40
    3,319
    135
    Feb 19, 2004
    Pepperell MA
    I just pulled apart a FJ60 that had a seized A/C idler roller... But the smog pump is usually the culprit.
    Nick
  9. PabloCruise
    PabloCruise SILVER Star
    17,417
    2,116
    Jun 3, 2004
    Northern Colorado
    I would bet air pump, but he said it is de-smogged, so I am guessing there is no mare air pump to deal with?
  10. Gumby
    Gumby Supamod Staff Member s-Moderator
    12,226
    679
    Dec 13, 2002
    Knee deep in hookers and gin
    My guess would be A/C compressor as well. Take the belts off and see what happens.
    Or have someone turn it over and look to see if the water pump/AC/ alternator turn.
  11. lowtideride
    lowtideride
    7,611
    Media:
    12
    Albums:
    1
    83
    Sep 29, 2003
    The Sunshine State
    Patty ya gotta get someone to look at the engine while someone turns it over...as said above. look for things that are not spinning ;)
  12. lowtideride
    lowtideride
    7,611
    Media:
    12
    Albums:
    1
    83
    Sep 29, 2003
    The Sunshine State
    maybe gumby just had the magic touch even though he is a heman2fhater...
  13. patride71
    patride71
    1,483
    91
    May 8, 2004
    i poked around under da hood and figured out the belt that was not moving was the smog pump/water pump belt. my rig is desmogged, but the smog pump is still there since it acts as a tensioner. my best guess is the smog pump is what is locked up as i assume the water pump would not seize? :confused:
    anyway, if its the smog pump what are my options? i don't want to buy a smog pump for a desmogged rig. but on another search i saw where if no smog pump the cat would get plugged up? don't get that since the pump is bypassed and basically is just acting as a pulley at this point. should i just buy a used smog pump and install?
    man its going to be a pain just to remove it. i can't even get my ratchet in to loosen the tensioner part of it.
    oh yeah, i my a/c is pretty much shot, but i do enjoy power steering, so Jman's "fix" is not an option..... :D
  14. swank60
    swank60
    1,484
    244
    Aug 26, 2002
    Easy - SOR has a smog pump eliminator pulley kit. It's $200 but wow, go figure, it's friggin' SOR.
    http://www.sor.com/sor/cat048c.tam?xax=5050
    head to the bottom of the page.
    It would probably be cheaper to find a used smog pump and put it in place, but the PS pump leak is going to lock it up, too - or getting it wet, or whatever the hell yoiu did to it. Probably find you a good cheap pump on ebay or here somewhere...double check it though, make sure it's not the water pump.
  15. swank60
    swank60
    1,484
    244
    Aug 26, 2002
    Actually, the SOR thing is friggin' $300. The mounting unit is $200 and the pulley to go on it is another $100.
    Find a used pump.
  16. patride71
    patride71
    1,483
    91
    May 8, 2004
    ok, so how do i tell if its the water pump or not?
  17. FJ40Jim
    10,352
    Media:
    1
    2,731
    Sep 26, 2003
    Cut the belt off and try spinning the fan/water pump and the air pump by hand.
    One of them is going to be stuck, most likely the AP. :frown:
    See this thread for a less expensive, more reliable smog pump replacement idler:
    smog pump idler
    You'll need a new belt also, seeing as how it's burned up and cut in 2 now. ;p
  18. dfmorse
    dfmorse
    1,518
    2
    Jul 7, 2004
    EVERGREEN, CO, USA
    patride71;
    Lets assume the engine runs and is making loud squeeks. Get a 3/8 inch wood dowel, place one end on the water pump and the other end to your ear. You will hear the bearing noise for sure. Do the same for other components. Don't get the dowel caught in the fan. You may be able to have the air pump rebuild. Buy a new water pump if that is the problem...
    dfm
  19. patride71
    patride71
    1,483
    91
    May 8, 2004
    its def the smog/air pump. i cut the belt off and couldn't budge the pulley on the pump. pulley for water pump/fan turns easily. i think i'm going the JMan route and going to get a smaller belt and bypass the power steering pulley.
    i just don't have the money or time, with my move going on, to deal with the pump or getting a SMOG PUMP IDLER (promo) from TLC. ;)
    anyone got the specs for size belt needed if no power steering?
    yeah i know....do a search. :flipoff2:
  20. patride71
    patride71
    1,483
    91
    May 8, 2004
    ok i see from doing a search the its the same size belt as the a/c belt.
    can't figure why my air pump froze up. doesn't look like my power steering pump has been leaking on it..... :confused:
