SQOD Squad - Stupid Question Of the Day
Ummm .. the console lid in my Tacoma is side hinged. It's pretty much impossible for the passenger to access the contents, very awkward. I wish it was hinged in the back, as they are in the 200 and 3rd gen Tacos.
I have to say… the new RAV console is pretty sweet
What's the purpose of mounting an inreach on the dashboard?
for a 2021 LC200, the position of the cloned tpms is irrelevant from whence it was cloned, correct?
Correct. My 2018 behaves this way. I have seen some instances where it may take some driving around for the position to be correct, but it will eventually get there.
What is this thick metal tube visible from the front passenger wheel well?
Noticed a slightly rusty bracket (I think?) the other day and wondering if that’s something I should put on the list to replace in the near future.
If it really bothers you, some CLR on a brillo pad will probably disappear it.
Thanks to tropical storm Rachel I joined the wet footwell club! Truck was parked outside in the rain all night. Got in this morning to get gas and breakfast. Didn’t notice until my second stop the all weather floormat on the passenger side had Pooled a decent amount of water! Carpets are totally dry. I’m guessing from the splashback of passing cars that hit my windshield some water made its way past that cowl seal. Haven’t checked the filter to see if it’s wet. Fun!!!
Edit: filter is dry. Cleaned the sunroof drains, tested both the cowl and the roof with a hose, couldn’t replicate it? Weird. I’ll take it :)
Don’t give up. Find the leak. Too much at stake to let water inside.
Definitely share your sense of urgency. I checked the cowl, it was full of leaves so I blew those out. Checked the seal on the plastic cowl and it’s sticking tight to the base of the windshield. Used a garden hose on full blast for several minutes to check both the sunroof and cowl seals/drains, both are draining perfectly to the ground. Pulled the cabin filter, it’s completely dry with no mold smell and no evidence of water drips. I’ve owned this truck for 2.5 years, driven 45k miles so far, and been through two rain and snow seasons without a drop of water. I really think it was the semi truck next to me on the freeway dumping gallons in a few seconds, the drain system just got overwhelmed. Still have the Toyota extended warranty, if it comes back I’ll have them replace the cowl.
Just received one lower control arm. It was dropped shipped from nj. I ordered from westboro Toyota in ma. Does it look fine? Some of the paint has flaked off?
Looks about like mine did.. only there were two in the box banging against each other (phrasing)
Just make sure the ball joint boot isn't torn.. beyond that I'd run it.
My center diff light flashes fairly often and I've learned to deal with it by driving a bit and then restarting the motor.
However, the worst part is that cruise control also stops working. Is this the case with everyone?
one or more of the sensors are dead..
this happens to me when I leave the spare tire at home sometimes which btw is one of the dumbest things. i know someone in here will defend that too but the fact that they programmed it to show NONE of the other tire pressures is beyond stupid.
I feel so stupid...
Last year when I put on my RW's, I installed 4 new Autel sensors, programmed with my trusty TS508.
I could never get it to work, I could OBD clone them, program them, the light would be off, but they would never read any pressure. After a halfhour trip the TPMS light would come on.
I thought it was just Toyota being picky about aftermarket sensors.
I was hoping to find a 5th RW for a spare, but that never happened. Going on a a roadtrip soon so I mounted up a 275/70/18 on a factory 18, with a factory TPMS sensor.
Sure as hell all the TPMS sensors are working fine now. This entire time all it needed was to see the spare tire...:banghead:
Late to the party, but I highly suggest you peel those stickers off and give those arms a proper coat of paint. The factory paint is pathetic. I bought a pair of those for my Tacoma, they were well packed, but the welds were already starting to rust when I pulled them out of the box.
I scuffed them with some 120 grit sandpaper, then a coat of Rustoleum red primer, then 2 coats of satin black.
