I'm trying to verify my own understanding on spring shims.
On an FJ40, rear, with factory spring under configuration, if one was to use a degree shim they would place it between the spring pack and the axle housing, right? Meaning, it would be on the top of the spring stack, and most likely, if using normal-length shackles, the thick part of the shim would be towards the front, in order to raise the front of the rear pumpkin by the degree of the spring shim. Right or wrong???
Reason I ask, is after a three week ordeal of having the wrong parts shipped, shippers not finding my address, and so on, just now a pair of 4" Skyjacker springs just showed up. They have a 3 degree shim bolted into the pack, on THE BOTTOM, where it will go against the spring plate, not the axle tube, and they have the round pin part of the spring bolt on THE BOTTOM, and they have the fat part of the shim to the rear - it looks as if it was assembled backwards, as if the person thought it was to be used spring over.
I know I need to rip the seller a new one, again, because his second attempt at sending the right parts didn't include THE SPRING BUSHINGS, but I also must decide if I need to disassemble and reassemble my BRAND NEW spring packs to correct the manufacturing error. If it is incorrectly assembled - should I bother to contact the manufacturer? They do have some issues at their plant, because the first set of springs sent had a shortage of bushings within the factory sealed bag, and now I strongly suspect they have another problem with assembly instructions at their factory.
Thanks for listening to my ranting, and would appreciate the wisdom sharing on the degree shim location.
