Spring Repair
jvazquez53
El Tractor
San Juan Puerto Rico
After a close inspection of all the accident damage to "El Tractor" I was looking at the front spring and since the rest of the springs are fine, I'm thinking to remove the spring, take it to a repair shop and have those two leaves removed and replaced. Why? The other three springs are fine, are part of a lifted kit and it will be cheaper to replace two leaves than to get a new kit.
Trapper50cal
TEQ Frame of Mind
Supporting Vendor
Durango, CO
Will you ever get it to match the other side? Maybe you should at least get the same thing done to both spring packs on that axle. You may be able to get it "close enough" but it may be a crap shoot too.
inkpot
All over Arizona
Howdy! I did just the opposite on my 72 FJ40 many years ago. The two long leafs were the only ones not damaged. I took both front spring packs into an industrial spring shop. They replaced the shorter leafs on both packs so they would be the same ride. Worked out fine for me. John
Trapper50cal
TEQ Frame of Mind
Supporting Vendor
Durango, CO
Now see, that touches on (kinda) my concern for this course of action...These springs (this spring) needs the leaf with the full loop for the bushings...(and theoretically a military wrap) it seems like those two leafs are the most important and the most expensive to fab...I would like to hear what a spring guy will quote for this job and how that stacks up against a new set
jvazquez53
El Tractor
I'm out of the US mainland, and most the time the cost of these is less. As soon as I get a quote, I'll post it. If the cost is too high, then I'll go for the new kit.
Mace
rock scientist..
Staff member
s-Moderator
Las Vegas
Any competent spring guy should be able to fab up new springs with a military wrap..
Cruiserdrew
On the way there
Sacramento, CA
x2
We have a spring shop here that could do that in an hour or two. I say it's worth a try. Plus, visiting spring shops is cool-it's like Vulcan's Forge.
Home
