Spraywash the engine? Any precautions?
Albuquerque, NM
Website
www.nmia.com
Any electrical/sensor issues with the V-8 when spraywashing the engine? I'm thinking if these things are made for serious off-road, they'd be somewhat immune to water under the hood & should be ok? Has anyone had any problems after doing it?
Donco,
Make sure you cover up your throttle position sensor, mass air sensor. I usually use aluminum foil. I also cover the connectors next to the throttle position sensor. I also just use Simple Green for a cleaner instead of engine degreasers.
How did your timing chain install go? Are you done? Thanks!
