Sprayer Systems (Windshield, Headlights, & Rear)
Discussion in '60-Series Wagons' started by WALoeIII, Oct 28, 2005.
  1. WALoeIII
    WALoeIII
    451
    2
    May 18, 2004
    Seattle, WA
    I'm trying to get this system all up to spec, but have run into a few issues. First, I have the replacement 90 degree joints for the headlight sprayers, but I can't figure out how to get the tubing off the old ones. Do I need to remove the entire headlight assembly (I took off the turn signal and outer bracket) or is there an easier way to do this? Second, where is the motor for the rear window sprayer? When I press the switch (this is supposed to spray no?) I don't hear the noise of an electric motor anywhere, is this run off the same reservoir as the headlights or the windshield. Thanks - still need to get that FSM :doh:
  2. chitown40
    chitown40
    2,112
    24
    Feb 9, 2004
    Buffalo Grove, IL
    There is a bag inside the driver's rear panel that should be filled with washer fluid. I think the pump for the rear is attached to it or nearby it.
  3. WALoeIII
    WALoeIII
    451
    2
    May 18, 2004
    Seattle, WA
    Where does it get its fluid from?
  4. cruiser_guy
    cruiser_guy
    11,197
    35
    Jan 20, 2003
    Wherever the truck stops!!
    The baggie is filled with washer fluid. It is filled through the round access in the side panel.
  5. oldman
    oldman
    31
    Oct 31, 2005
    right here
    And the pump for the rear is attached to the bottom of the bag.
  6. airon23
    airon23
    848
    Media:
    11
    Albums:
    1
    421
    Jan 5, 2004
    Reno NV
    I've been thinking of doing the same for the rear but need to replace cracked tubing in the rear. also the wiper doesn't work. I think it is due to wiring. In the process the PO "complete restoration" just cut s*** to get the body looking decent and throw some paint on.
