I have been searching with no luck. Has anyone done a write up on removing the transfercase with the manual transmision still on the vehichle? And or a transfercase rebuild? Iam loosing gear oil from the transfercase (no it is not going into tranny), it seems to be leaking at the gasket between the transfercase and rear portion of the transmision adapter plate. It also has a slight leak at the PTO shifting rod which I assume is an O-ring.
So when I pull the transfercase should I just replace the mounting gasket (assuming I could by it by itself)? Or is the smart step to put a full seal and bearing kit in? Or is this a pretty complicated job which I should probably take to a shop? If so what could I expect to pay? I live in Alberta, Canada
