Spiral Wrap "vs' Corrugated Wrap?
San Diego
Website
youtube.com
Hey Guys, Stupid Question, Not Really Tech, But...................... Curious on your thoughts!
Almost done with the Dual Battery Setup
Time to protect the cables now.
I was wondering what the general consenus thinks of the 2 types of cable wraps. What are the pros and cons of the Spiral and the Corrugated.
Who is using what and why?
So Far I Came Up With This:
Spiral Pros:
-Cheaper
-Easy To Install
-Easy to run a stray cable in or out of
-Looks better
-Available in many colors, including pink! :D
Spiral Cons:
-Some of the cable is still exposed
Corrugated Pros:
-Seems to possibly protect better (full wrap)
-More Common
-Blends in with rest of engine compartment better
Corrugated Cons
-Slightly more time consuming install (no biggy)
-ugly in my opinion
Any more input?
To me, corrugated looks better, and seems as though it will protect a lot better, it would be my choice.
What did Mr T use when he built it?
-B-
Spiral looks like shiat unless you a have ghetto Honda civic. Hell, most of them now days go with chrome corrugated, snazzy. At any rate the corrugated looks far more professional and is easier to add to in the future than spiral. My 2 cents.
Kevin;
I use a lot of spiral on my 40; It will only last maybe a couple of years and then fall apart.
trojan_knight said:
i would try to keep a stock look and that means corrugated and lots of black tape. at least thats what i find all over my 80
Yeah, i actually just finished the job of corrugating the entire setup! Wasnt that bad!
Here are 2 pics
IBCRUSN said:
. Hell, most of them now days go with chrome corrugated, snazzy. .
Thanks for holding out on this info jerk! If i knew this ahead of time, i woulda went chrome! :D
Chrome helps get you home right? :D
trojan_knight said:
thats nice, mangler!! how much are those marine switches?
i believe $35 or so
The avionics and hydraulics guys use a FAA-PMA spiral wrap at work where chafe might be a problem and the harness/hose cannot be rerouted, seams to hold up just fine for decades, it does not look like the cheap stuff at the auto parts store, it is a translucent white. Looks similar but not quite the same as Teflon, corrugated is never used, I assume because it is too thin to provide series chafe protection. Bundles that are not near other objects are just laced together with waxed cord every few inches to maintan the shape of the bundle
